Author: Arndt Muehlenfeld
Released: November 19, 2010
Requirements: VIC-20 (24K expansion required), Joystick or Mouse
Optional: SD2IEC / RTC, FE3, Protovision 4-player adapter
Description: A GUI file browser.
Download
Read more and discuss VIN here: Discussion
EDIT:
Update for release 2.
VIC-20 Software Releases of 2010
- Omega Star Commander
Author: Robert Hurst
Released: October 11, 2010
Requirements: VIC 20 with 8K RAM expansion
Description: A BREAKOUT clone.
Source:
GitHub
Download:
breakout.prg
Read more and discuss Break-Out! here.
Source:
GitHub
Download:
breakout.prg
Author: Mike
Released: October 21st, 2010
Description: Automatic generator for DATA loaders
Screenshot: none
Download: *.prg file
Discuss this program here.
Author: Mike
Screenshot: none
Released: November 21, 2010
Requirements: VIC 20 with 8k RAM expansion and a joystick
Description: A clone of a classic arcade hit. Written in ca65 assembler using the VIC Software Sprite Stack.
A discussion of its development is here.
Name: Theater of War
Author: Ghislain
With special thanks to: orion70 for feedback, PDF manual + alternate graphics.
Released: November 25, 2010
Requirements: Unexpanded VIC-20. Disk Drive is optional if you'd like to see the hi-res intro splash screen + loader instruction program before the main game program is loaded.
Description: A WW2 Tactical Strategy game where you play the role of a German general on the Eastern Front in Russia.
It is Spring 1943. After the debacle of the Wehrmacht at Stalingrad, the German High Command has decided to regroup to secure our position on the Eastern Front. Once the offensive is regained, the objective is to strike a final swift blow against the heart of the Soviet Capital. While you will be severely outnumbered, there is a dearth of quality enemy officers due to Stalin's Great Purge of military commanders who he deemed not loyal to pure communist ideology. You should use the enemy's inferior strategy to your advantage. Every unit you deploy will have strengths and weaknesses. Use them wisely!
There is also a two-player option.
Download it here: https://sites.google.com/site/gdbsite50 ... ects=0&d=1
Discuss it here: http://sleepingelephant.com/ipw-web/bul ... php?t=4847
Author: Ghislain
Name: Face Versus Heel
Author: Ghislain
Released: December 18, 2010
Requirements: Unexpanded VIC-20 + Disk Drive.
Description: A pro-wrestling simulator where the outcome is determined by a random number generator, but good tactics can maximize your chances.
The terms "face" and "heel" originate from wrestling's carnival days in the nineteenth century. "Face" (short for babyface) means hero, while "heel" means villain. Instructions are included in a text file with the download as well as within the game loader screen.
Discuss it here: http://sleepingelephant.com/ipw-web/bul ... 96&start=0
Author: Ghislain
Name: The VIC-20 Bible Series II: Pentateuch - 40 column version and graphics
Authors: Mike and Orion70
Released (final version): December 23, 2010
Requirements: VIC-20 + 24K RAM
Description: Browse the first five books of the Old Testament (King James Version) in full 40 column screen. You can select single chapters, and scroll the text with cursor up/down. Take a look at the hi-res cliparts used as "book covers", to graphic depictions of the main episodes of Graphics, and read about the very first steps of mankind in full 40-column text processing made using Mike's Minigrafik. Mike also elaborated a text compression / extraction routine to fit the whole Torah in your VIC-20 .
Download: d81 disk and batch file for easy program launch
To elevate your spirit, copy and unzip file to your VICE main directory, then double-click on pentateuch.cmd. Otherwise, expand your VIC to 24K, set the true drive emulation, the disk drive 8 as a 1581, then type LOAD"*",8,1. Wait for the program to load, then RUN and wait for the main menu to load (don't press any key at the intro screen).
Discussion here.
(mod: d/l link repaired)
Discussion here.
