Can't start Vic cartridges from VICE xvic command line
Neo-Rio
Postby Neo-Rio » Wed Mar 15, 2017 7:28 pm
I was mucking about with RetroPie trying to get CRT vic-20 cart games to start from the command line, but I keep hitting an error.
Then I tried it in Windows.... same problem
Note that I'm using Vice-3.0 on both.
xvic.exe -cartgeneric "<path to crt>"
I get : Argument "<path to crt>" not valid for option -cartgeneric
If the path isn't valid as an option, I clearly don't know what is.
I've been using CRT files from the vic-20 TOSEC that you can find on archive.org
I tried cosmic cruncher as a test, but it seems no matter what I put that path to the file in, it doesn't work.
Also tried running xvic.exe "<path to crt>" without the -cartgeneric but the emulator thinks it's a program file, drops it into an autostart.d64 and of course won't start either.
I have zero problems loading the CRT and getting it to work if I just do it through the xvic GUI and select a generic CRT. However I'm trying to get xvic to autostart with the cartridge.
Who is online
