Solved: How to use S and L commands in WinVICE monitor?
Dusty
Post by Dusty »
No matter what I try, I always get an "cannot open" error when I use i.e.
S "test" 8 1000 1DFF
From BASIC interpreter I can access the virtual disk in drive 8. I have to admit, that I didn't search the WinVICE website, because I thought, s.o. here might have the answer ad-hoc. :wink:
Quotes around the filename, and $ in front of the hex references.
Dusty
Post by Dusty »
Thx for reply. The problem was, that the built-in monitor obviously can't access the drive when in directory mode. When I use the disk image mode, it seems to work fine.
buzbard
Post by buzbard »
If you want to save to the "virtual drive" or a folder, just use:
s "test" 0 1000 1DFF
0 is the "virtual drive" from the monitor.
Dusty
Post by Dusty »
Good to know! Thx!
