Recording Video in VICE
I want to capture a video of programs running in VICE. I have the "Precompiled FFMPEG video/audio codec", but I'm not sure why it's not working for me. Can anyone give me an "idiot's guide" to making this work?
- Omega Star Commander
Under Snapshot menu, select option Save Media File...
Then change image format to FFMPEG, enter a filename, and start recording. You should see something like this, if invoked from the command-line:
I do not know how to make that happen from the command-line, if it is even possible. Help on this topic from the command-line and its built-in help is terse to say the least.
Output #0, avi, to '/media/retro/Commodore/VIC20/quikman+8k/quikman+8k.mpg':
Stream #0.0: Video: mpeg4, yuv420p, 416x256, q=2-31, 800 kb/s, 90k tbn, 60 tbc
Stream #0.1: Audio: libmp3lame, 44100 Hz, 1 channels, s16, 64 kb/s
I think I'm having trouble installing the FFMPEG files. I've unzipped and executed the files, but I haven't noticed any change in VICE. The FFMPEG options are still visible but inaccessible. Maybe the files are just not in the right place?
All the FAQs and documentation seems to assume that the user has installed it properly, so I'm too far away for that sort of help.
Yes, you probably are. You need the shared DLL files put in the same folder as WinVICE. A quick use of Cygwin's strings command on xvic.exe reveals:
I suspect these are the version numbers required for this xvic.exe build to work. I could not find a (trustworthy) site with pre-built 64-bit Windows binaries of this version, only the latest-and-greatest, AFAIK, will not work.
Can anyone point to a resource to fetch the proper goodies?
rhurst@Win7-vm /cygdrive/c/WinVICE-2.3-x64
$ strings xvic.exe | grep -i dll
opening dynamic library avcodec-52.dll failed!
avcodec-52.dll
closing dynamic library avcodec-52.dll failed!
opening dynamic library avformat-52.dll failed!
avformat-52.dll
closing dynamic library avformat-52.dll failed!
opening dynamic library avutil-49.dll failed!
avutil-49.dll
closing dynamic library avutil-49.dll failed!
opening dynamic library swscale-0.dll failed!
swscale-0.dll
closing dynamic library swscale-0.dll failed!
I simply cannot find the right files to record video in VICE. Or maybe I'm just putting them in the wrong place. Could someone send me a copy of their VICE folder with video working properly? The whole file should be small enough to attach to an email. It would really help with a big project I'm working on.
With VICE 2.3 you need these files:
http://iancoog.altervista.org/vice/ffmp ... vice22x.7z
(Click on "qui")
(Click on "qui")
Re: Recording Video in VICE
FYI, looks like VICE development is updating their builds to include ffmpeg source code, and allow for compiling it for either shared or static use. There's more configurable compile-time features, but resurrected support for native recording video is welcome!
I can confirm ffmpeg integration now builds and functions proper in xvic 2.4.17 r29409M (GTK+ AMD64/x86_64 Linux glibc 2.20 GCC-4.9.2):
Woot!
FFMPEG Driver: avi
AC: MP2(86016)
AC: MP3(86017)
AC: FLAC(86028)
AC: PCM uncompressed(65536)
VC: MPEG4 (DivX)(13)
VC: MPEG1(1)
VC: FFV1 (lossless)(34)
VC: H264(28)
VC: Theora(31)
FFMPEG Driver: mp4
AC: MP3(86017)
AC: AAC(86018)
AC: AC3(86019)
VC: H264(28)
VC: H265(1211250229)
FFMPEG Driver: matroska
AC: MP3(86017)
AC: AAC(86018)
AC: AC3(86019)
VC: H264(28)
FFMPEG Driver: ogg
AC: FLAC(86028)
VC: Theora(31)
FFMPEG Driver: wav
FFMPEG Driver: mp3
VC: (0)
FFMPEG Driver: mp2
Output #0, mp4, to '/home/rhurst/Videos/quikman+8k.mpg':
Stream #0:0: Video: h264, yuv420p, 416x256, q=-1--1, 800 kb/s, 60.28 tbn, 60.28 tbc
Stream #0:1: Audio: mp3, 44100 Hz, mono, s32p, 64 kb/s
ffmpegdrv: Initialized file successfully
Sound: Opened recording device device `soundmovie'
please test this stuff extensively and report problems ASAP - you never know when andreas loses interest and crawls back into his cave =) (you can find winvice builds here: http://vice.pokefinder.org )
