Spanish translation
formater
Spanish translation
Post by formater »
I need your Help!
I want to translate VICE to spanish. I think this is possible, because in the language menu you can select many languages, but not spanish.
What program need to made this. In another emulators like WinUAE is a easy task, because the no english language is in an external DLL an you can use a resource editor to made a spanish one, but in VICE seems that the languages are buil in the EXE program.
Thanks in advance
Bacon
for breakfast
Post by Bacon »
You would have to download the source code and edit the texts in there. I haven't looked at how the interface texts are handled in the source but I would guess that they're stored in separate source files so it shouldn't be too difficult.
At least one person from the VICE team is a Denial member, Marco van den Heuvel (blackystardust on Denial). He should be able to help you.
Bacon
formater
Post by formater »
Thanks for your help. I download sources, and in a directory called PO you find a xx.po file with plain text for translations. unfortunately, my knowledge of C and ASM compilators is = 0 :oops:
Zeela
Post by Zeela »
Use poedit (http://www.poedit.net/) to make a spanish .po-file and then send that po-file to the viceteam for inclusion in their next release
Check out my humble collection of old 'puters an such
http://www.zeela.se
formater
Post by formater »
Thanks Zeela
Working.....
Boray
Musical Smurf
Post by Boray »
I actually have mine set to English because I don't like the Swedish translation. He has translated too much. Things like joystick and cartridge are translated to strange words while all Swedes actually uses the English words for those. I wrote to him about it once but... of course... he didn't agree as it was his translation.
TBCVIC
Post by TBCVIC »
Reminds me of an old manual where they had translated sprite to "andeväsen" or something like that :)
Ola Andersson
formater
Post by formater »
Translation is a very dificult task, and as Boray say not all the people are happy with translatios, but at least you HAVE a translation (sweden), and is very strange thas isn't there any traslation to spanish.
I am not the more appropriate for this task, because my knowledge of english isn't very good, but is no one do it, I'll do it.
The problem of terminology , as Boray say, is the same in spanish, for example, joystick was translated as "palanca de juegos", but no one use this name in Spain, all the people use joystick (even with english pronunciation), evidently I'll use joystick in translation, hardware or software not ever have translations, etc.
Well, I have a hard task, because are a pile of lines to translate, but bit by bit I hope complete the work and insert a line "spanish" in the menu "language"
formater
Post by formater »
Problems wiht some words,
In informatic terminus who really means
Idle (trap idle) (timpo inactivo)
Smart (smart-attach cartridge image) no translation, because is the name of the cartridge
formater
Post by formater »
Well, finally I completed the task, 2885 lines translated to spanish, and I hope the new versión will have this translation in.
