Preliminary VICE build for testing.
We have fixed a number of bugs in xvic and would like some feedback.
Please test this with as many things as you can and report any emulation bugs you find in here or alternatively on #vice-dev @ freenode.net.
Preliminary build: xvic-r22708-win32.zip
- autostarting bug (which usually happened with TAP files) fixed
- Problems with attaching 4kb carts fixed.
- LOAD without ,1 mode (-basicload, no win32 UI yet)
- Vic Flash Plugin support
- several other changes.
Re: Preliminary VICE build for testing.
Finally.tlr wrote:- LOAD without ,1 mode (-basicload, no win32 UI yet)
I've found a redraw issue in VVV, the checkerboard zoomer right at the beginning. VICE does not correctly update the display with Video cache on (the error disappears when Video cache is ticked off).
Also, I had a *.d64 mounted in a 1541, in drive #8, with true drive emulation on. During testing I wanted to change to a 1581 instead, set to 1581 in 'Peripherals ...' (with the intention to subsequently mount a *.d81) and got:
Assertion failed!
Program: D:\WinVICE 2.2\xvic-r22708-win32.exe
File: drive.c
Line: 670
Expression: led_pwm <= MAX_PWM
I have to use that as an option from PRG Starter's Start button.tlr wrote: - LOAD without ,1 mode (-basicload, no win32 UI yet)
Thanks!
- Mayhem
- High Bidder
- Omega Star Commander
A 4k game ROM image (exactly 4096-bytes, with no 2-byte header), works fine using the -cartA option.
WOW very nice news !!!tlr wrote:We have fixed a number of bugs in xvic and would like some feedback.
Any improvements on NTSC timing emulation ?
I hope this is present in the other emulators as well, not just xvic, right?tlr wrote:- LOAD without ,1 mode (-basicload, no win32 UI yet)
With the current approach vcache is "too hard to fix" (quoting nojoopa), "please disable vcache".Mike wrote:I've found a redraw issue in VVV, the checkerboard zoomer right at the beginning. VICE does not correctly update the display with Video cache on (the error disappears when Video cache is ticked off).
This comment on pouet indicates it's been this way for quite some time.
No.nbla000 wrote:Any improvements on NTSC timing emulation ?
Very little work is done on NTSC emulation in general as most VICE core developers only have experience from PAL-land.
Progress is dependent on someone coding NTSC test programs and testing them on real NTSC vics.
We would very much like volunteers/contributors to create more test programs.
Once a fairly isolated test case exists, emulation can probably be corrected by someone on the team.
(Current test programs are all here: http://vice-emu.svn.sourceforge.net/vie ... testprogs/)
Join us on #vice-dev for real time discussion on this!
OK I will do some Tests with my working in progress SJLOAD version for NTSC machines to check if there is an emulation problem.tlr wrote: Very little work is done on NTSC emulation in general as most VICE core developers only have experience from PAL-land.
When is the next VICE version planned to be released?
New build: xvic-r22723-win32.zip
xvic changes:
- Video Cache repaired.
In other words, when the testers on this and other forums actually tested this enough to avoid the mess we got into with 2.2.
xvic changes:
When it's ready.Boray wrote:When is the next VICE version planned to be released?
This new quirk does not affect emulation, but there is this strange one-time video flicker and sound interrupt about 3-seconds after the program autostarts. I am using a Linux build with the SDL option.
Is that an outcome of the new "autostart-warp" load feature syncing back down? It seems when you +autostart-warp, that A/V interruption does not occur. No big deal, mind you.
I'm using new beta versions until you published the first version and I've not noticed any strange issue at the moment, NTSC emulation seems like the old version so not perfect but is another story...tlr wrote:when the testers on this and other forums actually tested this enough to avoid the mess we got into with 2.2.
Is there a Windows build of the whole VICE (and not just xvic) somewhere so that I can try it with PRG Starter?
