running ROM games - Let's start with Ms. Pacman
- Vic 20 Devotee
Hello. I am having a devil of a time running some ROM games on my emulator or my original vic.
http://zimmers.net/anonftp/pub/cbm/vic2 ... index.html
The above link has a MS Pacman game that has A000 as the load address. The only way I have ever run these is loading into an emulator and then resetting the emulator. This does not work for Ms Pac. Any ideas? How could I run this on the 16K expanded vic?
Any help would be appreciated.
Jonathan
Jonathan
- Mayhem
- High Bidder
- Vic 20 Devotee
- Mayhem
- High Bidder
Assuming you're using Vice as your Vic20 emulator... download both Ms Pacman files from the link you provided and fire up Vice with no expanded memory selected.
You then need to do:
File -> Attach Cartridge Image -> 4/8k at $A000 and choose the Ms Pacman-A000 file
File -> Attach Cartridge Image -> 4/8/16k at $6000 and choose the Ms Pacman-6000 file
Then do a soft reset (Alt R) and the game should boot...
With PRG Starter, double click the 6000 part, then drag and drop the A000 part into the VICE window, then press Alt-R to start.
- Vic 20 Devotee
Thanks. I was able to get it to run in my emulated environment.
How about on the real VIC? How would I do it? Load both and then do a reset?
Jonathan
Jonathan
Mayhem wrote:Assuming you're using Vice as your Vic20 emulator... download both Ms Pacman files from the link you provided and fire up Vice with no expanded memory selected.
Yes, load both ,8,1 and then do a SYS64802
but you need to set your ram expansion to block 5 and 3 first.
- Vic 20 Devotee
When I set my 16k expander to block 3 and 5, load each piece, and sys 64802 it displays the color and then locks up. Not sure what to try next. I tried loading both the 6000 and the A000 in different orders.
One thing was strange. Whenever I loaded the first piece and tried to load the second I receive an out of memory error. I type NEW and then loaded the second piece. Perhaps this is the issue?
Jonathan
Jonathan
Boray wrote:Yes, load both ,8,1 and then do a SYS64802
No this is normal or if you prefer it is a normal Basic issue.vicassembly wrote:One thing was strange. Whenever I loaded the first piece and tried to load the second I receive an out of memory error. I type NEW and then loaded the second piece. Perhaps this is the issue?
The problem is that MS-Pacman and Moon Patrol require both an hardware reset instead of a common soft reset used for other cartridge image btw there is a way to run them with a "clean" soft reset not well-known yet.
Below there is a sample program to automatically load mspacman from any drive:
1 ONAGOTO4,5
2 DR=PEEK(186)
3 A=1:LOAD"MSPACMAN60",DR,1
4 A=2:LOAD"MSPACMANA0",DR,1
5 POKE37138,0:POKE37139,0:POKE37154,0:POKE37155,0:POKE37150,127:POKE37166,127:SYS64802
- Vic 20 Devotee
Thanks! This bit of code worked perfectly.
nbla000 wrote:No this is normal or if you prefer it is a normal Basic issue.vicassembly wrote:One thing was strange. Whenever I loaded the first piece and tried to load the second I receive an out of memory error. I type NEW and then loaded the second piece. Perhaps this is the issue?
Line 5 is the "clean" soft reset if you want to type it manually after loading.Code: Select all
1 ONAGOTO4,5 2 DR=PEEK(186) 3 A=1:LOAD"MSPACMAN60",DR,1 4 A=2:LOAD"MSPACMANA0",DR,1 5 POKE37138,0:POKE37139,0:POKE37154,0:POKE37155,0:POKE37150,127:POKE37166,127:SYS64802
Nothingvicassembly wrote:Thanks! This bit of code worked perfectly.
If you want an easy way to load any Vic program, cart image too, try my CBM-FileBrowser, I will integrate it on next Mega-Cart firmware revision too.
