8K or 16K?
Mikey_C
8K or 16K?
Postby Mikey_C » Wed Feb 07, 2018 12:56 pm
Hi guys (& gals)
I used to know this a Loooooooong time ago, but I can't remember now.
So, If you load an 8k expanded game into 16k should it work? I ask because I just got Bonzo by Audiogenic on tape and it crashes upon loading
I only have a 16k expander.
MCes
Re: 8K or 16K?
Postby MCes » Wed Feb 07, 2018 1:42 pm
the vic 20 recognize at startup 3 possibility:
1) default memory asset
2) +3k (low basic) ram expansion
3) contiguous ram expansion from first 8K expandable ram (8,16,24K)
so if the game need a 8k expansion ram it can be loaded into a 8k or 16k or 24k expanded VIC20....
http://sleepingelephant.com/denial/wiki/index.php?title=VIC-1111_16K_RAM_Cartridge
“Don’t argue with idiots because they will drag you down to their level and then beat you with experience” (Mark Twain ?)
Mikey_C
Re: 8K or 16K?
Postby Mikey_C » Wed Feb 07, 2018 3:33 pm
Cheers fella. Thanks for reminding me. :)
As it happens the problem was the cassette was too tight, luckily it had screws, untightening, rewind/forward a couple of times sorted out the problem.
But thanks for the reminder :)
Return to “Hardware and Tech”
Who is online
