Vic 20 black screen :(
Hello
I've bought a very sick Vic 20 which is very yellow and has 2 keys broken off. My main issue when i power it up it does not have a picture its completely black.Any suggestions what to check first ?
Thank you
Sonic
Thank you
Sonic
Re: Vic 20 black screen :(
What kind of power supply plug is on it? It's either a two pronged connector or a multiple pin round din connector. The latter being the CR (cost reduced) version. Power supply voltages is always the first thing I check. You can also reference this repair doc: http://personalpages.tds.net/~rcarlsen/ ... /vic20.txt for ideas. There are a lot of causes of a black screen. It is a process of elimination. Initial Prime suspects are the Kernel ROM and VIC. But I would start by carefully re-seating all socketed chips.
-Autobiography of Mark Twain
It seems i have sound when i plug in a game cartridge but no video.. So i assume the CPU is working ? So my VIC is dead !!!
You cant assume the VIC is dead yet because it is responsible for sound output also. How are you connecting it to the tv? Is it the CR version (see above) or the older type VIC-20? It's harder doing a diagnosis without knowing.
I have a din cable (from the Vic 20) going to composite video to 1084s monitor.norm8332 wrote:You cant assume the VIC is dead yet because it is responsible for sound output also. How are you connecting it to the tv? Is it the CR version (see above) or the older type VIC-20? It's harder doing a diagnosis without knowing.
The Vic 20 M/B ASSY 250403 / FAB NO 251040--01 Rev D
That means you've got the CR variant, which needs the PSU with the DIN plug plugged in on the right side of the computer.Sonic wrote:The Vic 20 M/B ASSY 250403 / FAB NO 251040--01 Rev D
The video chip in the VIC-20 reacts quite sensitive to a slightly malfunctioning PSU. In that case, it tends to stop video generation but still works when a working PSU is connected. Do you own a multimeter for checks and know how to use it?
This could simply be iffy cabling of the video signal. The VIC-I chip inside generates both video and sound, it's very unlikely that it still produces sound but no video anymore.It seems i have sound when i plug in a game cartridge but no video...
Yes i do own a fluke multi meter & i know how to use one.. Checked both voltages from 2 different PSU and both measured the same voltages..
As for the cabling i tried with 2 cables and i still get no picture but with sound.. This has got me stumped..
You should check the ripple on the +5V supply by setting the fluke to AC. That ripple should not exceed, say, 0.1 Volt.Sonic wrote:Checked both voltages from 2 different PSU and both measured the same voltages..
You could build an own cable by combining a DIN-RCA breakout adapter and a AV cable like I did here (this one also carries a separate chroma from a S-Video mod). Other than that, you'd need to buy a known working VIC-20 and test the presumably non-working VIC chip in it. Also, the video circuitry around the VIC chip could be the culprit, but then you need a scope and a good read of the schematics to further diagnose this.i tried with 2 cables and i still get no picture but with sound.. This has got me stumped..
Thanks Mike I'll give those suggestions a go
- J.E.E.K.
- Website: http://klasek.at/8bit
Recently I got a VIC 20 with the same symptoms. After checking all the voltage stuff ...
Take a closer look to the black screen on power on if the screen is turned on very bright. If the VIC chip is still working (kind of) you will see some vertical ghost patterns all over the screen in character intervals. They are trembling around as long the CPU is trying to execute the reset procedure, coming to an end after a short while (probably the CPU get stuck on some point).
In my case it was the KERNAL ROM which was gone. Checked it with a analyzing ROM replacing the original one. Others told me, this isn't unusual. ROMs seem to be more sensible in this regard then expected. Got the ROM replaced by a conversion socket with an EPROM ...
Game cartridges didn't work either because the module procedure in the KERNAL had not passed yet.
Fixed !!!!
- J.E.E.K.
Fine!Sonic wrote:Fixed !!!!
Was it the Kernal ROM?
Or what else?
A dead 6560-101J.E.E.K. wrote:Fine!Sonic wrote:Fixed !!!!
Or what else?
