Constructed my VIC 20 breakout box
ViperSan
Post by ViperSan »
Didn't like the Idea of adapting and cutting cables so after doing the S-video mod ..I decided to design and construct a breakout box for the VIC20 rear ..
Made with a dual phono output to connect the audio to my monitor which is stereo ..so paralleled up the phonos ..
Then fitted a panel mount S-video socket wired as standard so any S-video lead can be used..
The whole lot including a small piece of stripboard ..and a 5 pin DIN without the shroud all fits neatly inside a box made from upvc cable trunking ..
Not glued it up as yet as I still have to test the audio ..
but here are a couple of pix.
rgds
VS
ViperSan
Re: Constructed my VIC 20 breakout box
Post by ViperSan »
Sound Checked with a game cartridge ..
Time to glue the box ..and re-assemble the VIC..
:D
