I found this on ebay:
http://m.ebay.com/itm/COMMODOR-64-VIC-2 ... nav=SEARCH
No idea what this is. Anyone?
vic 20 - c64 adapter...
- mrr19121970
- Vic 20 Nerd
Re: vic 20 - c64 adapter...
Ah. That tread gave some useful insight. I then visited the sellers eBay store and found a opto output board from the same maker which is probably what this adapter plugs into:
http://www.ebay.com/itm/COMMODOR-64-OPT ... Sw241YgZQl
All from the same "Simple Interface System".
I seem to recall a C64 cart adapter which allowed you to connect a 16K VIC-20 RAM cart. You would load up dumped C64 cartridge images into it and it could play them...
