commodore wont hook up to tv
hijohnshere
Occupation: student
Post by hijohnshere »
hello im 17 and have never really done anything with old computers i recently acquired a commodore vic 20 and cant get it to display an image on my tv i think i have it connected but it wont boot any ideas?
Re: commodore wont hook up to tv
Welcome to Denial. There could be several things that mean you're not seeing a picture. Can you give us some information to help track it down?
Is the VIC known to be working, or is it "untested"?
Does the LED come on when you switch it on?
How are you connecting it to the TV? Using the modulator (box with a DIN plug then lead to an aerial socket) or a composite cable?
Do you get any image at all? Does it change at all when you turn the VIC on?
tonyrocks
Website: http://www.tonyrocks.com
Occupation: IBM Watson Engr
Post by tonyrocks »
Do you have an RF-Modulator? It should look something like this:
The one end plugs into your VIC, the other end plugs in to the back of your TV ANTENNA port...you may need to find a COAX cable to plug it in. On the RF box, pick channel 3 or 4, then tune your TV to Antenna, channel 3 or 4.
