Bad colour ram
mrr19121970
Bad colour ram
Post by mrr19121970 »
Which is the colour RAM?
http://personalpages.tds.net/~rcarlsen/ ... /vic20.txt
UE1-UE6 2114 or TMM314A SRAM MEMORY
Blank screen. Partial failure: less than normal "3583 BYTES FREE" at
startup, sometimes will produce "garbage" screen or screen freeze after
warmup. Shorted chips may get very hot. NOTE: UE1 is used to generate
character color.
Re: Bad colour ram
Normally, I'd want to know whether it is a 2-prong or DIN plug VIC-20, but in this case, it's irrelevant: the colour RAM is UE1 in both PCB revisions.
Indeed it appears as if bit 2 (value 4) is 'shot' (i.e. stuck at 0) for some of the nibbles. In a similar fashion (blue -> red), yellow should turn to cyan in some places, green to white, and purple to black.
mrr19121970
Re: Bad colour ram
Thanks it is 9v.
Update
Ha, I thought I could whip a 2114 off my C128. Wrong RAM. Any tips on what to buy?
mrr19121970
Re: Bad colour ram
This is exactly how it behaves....
I replaced UE1 with a socket, and tried both new chips. SAME issue. No chip = no colour
mrr19121970
Re: Bad colour ram
UD1 CD4066 QUAD SWITCH (LOGIC GATES)
(UC2 in very early version) Screen characters have incorrect colors.
mrr19121970
Re: Bad colour ram
4066 replaced. Colours back to normal. Another 9v saved from the landfill
Re: Bad colour ram
Makes one wonder how the 4066 "managed" to let through bit 2 for some of the characters but not others.
We should have tried to rule out a faulty 2114 by reading back from it (with "AND 15", of course).
mrr19121970
Re: Bad colour ram
I don't know. I noticed the chars also were not always wrong. Typing an pressing delete sometimes corrected colour (or made colour wrong when correct before).
The WIKI troubleshooting guide was amended for this issue
mrr19121970
Re: Bad colour ram
