Freeze after warmup
- Website: http://retrocomputingarchive.blogspot.fr/
Freeze after warmup
Hi
One of my Vic 20s (C64 power plug) has the following problem:
it freezes if IN BASIC mode after some time but it works rock solid if I use a cartridge.
Once it freezes I sometimes get a white screen with visible borders and a restart is only
possible after some time. Something is heating up too much and causing a problem, ONLY
visible in BASIC.
Is the BASIC rom the most likely culprit?
Should I test the RAM chips?
Linzino
visible in BASIC.
Linzino
- mrr19121970
- Vic 20 Nerd
Re: Freeze after warmup
Which cartridge are you using?
You should try text (Scott Adams adventures), graphics (avengers) and multicolour (gorf) too to check the symptons.
1st guess is a damaged VIC-I chip. Try Ray Carlsons heat sink recommendations with epoxy and copper making contact with the RF cage.
http://personalpages.tds.net/~rcarlsen/ ... 20sink.jpg
http://personalpages.tds.net/~rcarlsen/ ... nk%202.jpg
Hi
All cartridge games seem to work rock solid except the ones that require BASIC to start.
The Vic-I seems OK to me.
Well, some of the Vic-20's had poor solders and as things heat up over time it could be a solder that has a crack in it.
If so, I would suspect something connected to the Basic ROM or related memory (<$0400).
My VIC suffered this same issue, swapping the BASIC ROM with another system and the problem followed the faulty ROM.
Hi
My description of the symptoms was not accurate.
Vic-I is and CPU are OK because swapped with working and tested ones.
Things are worse: some game cards do not work:
- Dig Dug is stuck/frozen at start-up with no music
- Deamon Attack seems to work but the main ship is not displayed.
BUT most other single color (Avenger) and multi-color games (Gorf) seem to work with no issue.
Which chips are the most likely culprits?
I now think the BASIC rom cannot be the (only) problem.
- mrr19121970
- Vic 20 Nerd
As I suggested over PM.
Ram or char rom maybe. Psu could be a cause too?
I fear it is something else because:
- Dig Dug is not using any built-in characters and a failing character rom should not freeze such a game
- RAM may be the issue but I cannot detect any corruption on the screen even if I re-map video memory to different
locations (poke 648,x: sys 58648)
- PSU is OK because used with lots of other Commodore computers
If these games use timers then perhaps one of the VIAs is faulty?Linzino wrote: Things are worse: some game cards do not work:
I have also swapped both VIAs with working ones and nothing changed.
I confirm:
- CPU OK (swapped)
- both VIAs OK (swapped)
- VIC-I OK (swapped)
- PSU OK (works fine with all other VIC20s and C64s)
Symptoms are:
- Dig Dug frozen at startup with no sound and
- Daemon Attack (main ship not shown)
- Basic freezes after a few minutes
The other cartridge games work solidly with no freeze.
No corruption is seen on screen at start up and no corruption could be
detected if I remap the video memory to different locations through poke 648,x:sys58648.
I confirm:
- CPU OK (swapped)
Symptoms are:
OK, so we're starting to run out of candidates.
My top suspect would be RAM, if page 0 or 1 were faulty then all sorts of odd behaviour could occur.
This is a CR model right? So you have a single 2K x 8 RAM chip?
This is a CR PAL model with
2 6116 chips (2kbyte each)
and
3 2114 chips (0.5kbyte each) including color ram
Previous problems fixed
This model had a loading issue which I fixed by swapping a faulty 7406 (UB4).
By doing this I inadvertently cut one line which I repaired with a bridge.
One more line was slighly scratched but continuity seemed OK to me
on all lines.
and
on all lines.
The specific graphical problem seems to occur in those games that seem to do some tricks
with the raster and probably with the timings to get more colors such as:
- Atlantis (ships have just one color instead of the many colors expected)
- Daemon Attack (ships are not shown but the bottom is shown)
- Dig Dug (freeze at startup but I do not know if it is using any tricks with scanlines)
BOTH plain high resolution and multicolor modes are OK in most games.
Should I also suspect the 7402 (MASTER CLOCK OSC)?
That one beforehand:
Missing interrupts will make the cursor stop blinking and the keyboard wouldn't work anymore. To differentiate this from a real CPU crash, try the following: as long you can type in something in BASIC (before BASIC "freezes"), type in this small program and run it:
When the interrupt stops working, TI$ freezes. However when the CPU still operates, A keeps ticking, and that will show.
If that was faultly, the VIC-I wouldn't display anymore, so we can exclude that for the moment. I would suspect, that the circuit trace of the IRQ line is the culprit. Can you check for continuity between Pin 21 of VIA #2 (UAB1) and Pin 4 of the 6502?Linzino wrote:Should I also suspect the 7402 (MASTER CLOCK OSC)?
1 A=A+1:PRINT A, TI$:GOTO1
The CPU sort of froze but the CPU is OK because I have swapped it with a good one. I can recheck.
I have attached:
- a photo of a bad fix for a 7406 with a slighly scratched line and a repaired one
- Atlantis on a good Vic 20 with colored ships
- Atlantis on the bad Vic 20 with missing and wrong colors
- a screenshot of the counter program frozen (I used TI instead of TI$ to see smaller intervals):
the time and the interger counter stopped at the very same time)
At the moment I don't have a multimeter at hand. Once I get one I will check the lines you suggest.
I have attached:
