What PCB layout software do you use?
I have a project thats borderline to work, but for now only a home project. With that in mind I don't want to spend too much on the PCB layout & simulation software. I was thinking of Proteus but finding a model of the 6502 was more like mining old labs and the only thing that looks usable is to import a multicomponent model (http://www.6502.org/users/dieter/m02/m02.htm) which is not really what I want.
Anyone had any success at finding a good platform with a 6502 included?
Re: What PCB layout software do you use?
I use Diptrace primarily now but used Eagle for about 12 years. Depending on what you are up to, both have free versions which may cover your design.
I don't know if either have the 6502 built into the libraries, but I can create libraries for any parts that you need if you decide to use either one of those.
Aaron
Aaron
Ok, I'll check it out! I also looked at CircuitLogix which is more integrated with its own internal spice implementation. For now, the best thing I have found is the spice model at http://www.visual6502.org which is probably very accurate, but also very slow.. Importing it into CircuitLogix may be a little cumbersome.amramsey wrote:I use Diptrace primarily now but used Eagle for about 12 years. Depending on what you are up to, both have free versions which may cover your design.
Aaron
What spice model did you base your 6502 simulation on?
I don't have a good answer for simulation... simulating a cpu in circuit means running code on the cpu which is beyond most simulators for pcbs. So normally just a few thought experiments and then build the pcb and try it out. Boards are only a couple of bucks these days so it doesn't take much to try out some ideas in real hardware.
I use EAGLE:
I've toyed with DesignSpark and other tools, but always come back to EAGLE.
Jim
- It has a free (as in beer, not speech) version that hobbyists can use
- It has auto schematic->PCB annotation, which most other lighter weight tools don't have (I know, it sounds like a hokey feature, but it is invaluable to add a part on the schematic and it shows up right away on the PCB design)
- I have learned to be really good at it. Yes, the UI is not the best, but man I can crank out designs all day long now
- Many hobbyists use it. Look at Make Magazine, etc.
- Lots of libraries. Sparkfun, LadyAda, etc.
- Many open source projects use it so the designs will be easy for others to replicate. Since I exclusively do FLOSS, it seemed appropriate.
Jim
I use Altium Designer for my projects. Of all the professional packages I have used this is the best. Very good balance between enterprise and flexible.
There are perhaps few that can buy such a package as a hobbyist. So among the more available free or low cost, I would also go with Eagle. Especially since it is almost de facto standard among open hardware etc.
For simulation I use various versions of spice. I only simulate analog circuits. I see little point in simulating digital or MCU circuits. Exception FPGA.
Thomas Lövskog
Thomas Lövskog
An earlier version of Altium was used to create the Behr-Bonz schematic and PCB layout back in 2008.
Its an excellent software IMHO.
I learned on "Tango" which is probably kindof unknown today back then it was the only package (available for mortals) that had a half working auto router (which was used to teach us to never use the autorouter =P). For personal small things i use eagle, mostly for the reasons brain mentioned. Company uses Altium, but i havent done much with it yet. If i'd start today i'd probably prefer KiCAD, mostly because its really free and thats a very strong point for me when it comes to tools.
- Schema
- factor
I use Fritzing. Free, open-source and pretty easy to use. Targeted at beginners (like me), but lacks a few features and the part library is a bit strange.
http://fritzing.org/home/
- Schema
- factor
I also want to look into Upverter which is a kind of neat spin in that it's online / collaborative with change tracking and so on (kind of a github for hardware projects).
https://upverter.com/
Ok, I settled on Eagle. I have bought some W65C02 and W65C22, both in PLCC-44 package. I also bought some holders with standard 0.1" spaced pins, so it all looks nice. I found a Eagle W65xxx library, but it only contained the DIP-40 package. Do you have libraries with these (e.g. PLCC-44) in them?amramsey wrote:I use Diptrace primarily now but used Eagle for about 12 years. Depending on what you are up to, both have free versions which may cover your design.
Aaron
I will put those symbols/footprints together in the next few days for you.
Oh, great!amramsey wrote:I will put those symbols/footprints together in the next few days for you.
I have tried to put together my first layout and I must stay I'm quite green on this, even after years experience with making semiconductors and doing alot of programming. PCB layout just haven't gotten my attention.
Well, I tried to make a 65C02 coprocessor and a scheme to plug it into the Vic-20 expansion port. The basic idea is to share some memory and I added some flip-flop to actually set the "RDY" flag on the 65C02 so that it doesn't run until the 6502 of the Vic-20 tells it to. I also added a 65C22 and I have a feeble idea of paging a 128KB SRAM so that the Vic-20 gets some more memory to play with (e.g. 34K * 2).
Here is my current layout.. version 0.1 pre-alpha (and please ignore IC3 at the moment)
EDIT: version 0.2b pre-alpha... now also with Bluetooth LE and 20+ fixes.. Still need to fix the $400-> writes as the logic only works for the 6502.
EDIT2: version 0.4blue pre-alpha... parts of the circuit are up and running, so I can read/write to the memory chip from the Vic-20. Some bus stability problems on the external bus, but it can probably be fixed with some resistors.
Notes:
* The 65C02 should run faster than the 1MHz clock of the Vic-20. 10MHz should be possible.
* I will add a battery to keep the SRAM memory alive, even without power. It should enable some program at BLK5 to autoboot.
- joshuadenmark
- Big Mover
@kakemoms
Looking good, wil follow this with excitement.
Well, debugging is kinda slow but it seems to get closer each day with the bus interface and memory mostly done:
Strange thing happends if the databus (D0-7) opens at wrong times. Most noteably the character colours gets randomized. I didn't think the 6561 could see the external memory, but it looks like it can somehow..
