Possible char rom failure ?
- mrr19121970
- Vic 20 Nerd
- mrr19121970
- Vic 20 Nerd
Re: Possible char rom failure ?
I will try desoldering later. The IC seems to be very hard to come by, and might not be economically viable?
NOS 25 euro
Replacement 21 euro
anyone have a more economical source?
Update. Desoldered and put in working machine. Same issue. Confirmed char rom. Inserted working one and all good
NOS 25 euro
Replacement 21 euro
Not used them, but this Italian seller on eBay has modern replacementsmrr19121970 wrote: anyone have a more economical source?
http://www.ebay.co.uk/sch/8bit_fan/m.ht ... 1543.l2654
- mrr19121970
- Vic 20 Nerd
Thanks, it's the same seller. I am chatting with him now.
You can also build your own adapter board and program a 2732 EPROM using these
http://store.go4retro.com/23xx-adapter/
WRONG!srowe wrote:You can also build your own adapter board and program a 2732 EPROM using these
The 2732 is 24pins and is not compatible with this type of adapter. This adapter is for 2764 up to 27512 types of EPROMs.
I have a spare character generator ROM for the VIC-20, asking 9 Euros. Cheaper hum?
- mrr19121970
- Vic 20 Nerd
I will take it
Update. Payment sent.
- mrr19121970
- Vic 20 Nerd
Many thanks @eslapion. Dropped in. Works. Can it be that ntsc vic20s have better image than pal ??
IMHO, yes. The color encoding in PAL can sometimes cause weird degradation of image quality when some color combinations are used.mrr19121970 wrote:Can it be that ntsc vic20s have better image than pal ??
