What SD devices are those?mrr19121970 wrote:Me too, but I also added the grips as it is a pain to remove.
Manosoft Princess device (split from: Datasette Questions)
Re: Manosoft Princess device (split from: Datasette Questions)
- mrr19121970
- Vic 20 Nerd
The green one is the C64funs mini SD2IEC (32 euros + postage) and the white one is the JenMa NE-sd2iec (29 euros + postage). Both offer a descreet solution near to built in. The green is lower profile so better suited for C64C/C128 cases, and the white one works better with breadbin due to slightly larger size.
- mrr19121970
- Vic 20 Nerd
It you want to save a TAP file to a cassette, how do you do it ?
This was my 1st thought, also confirmed in then manual:
I was thinking there was some utility feature to do this.Note: during the loading operations it is possible
to press Record & Play buttons on a C2N recorder
attached to the C64SD card to save the data to
the recorder.
- mrr19121970
- Vic 20 Nerd
After multiple attempts (2 datasettes and 2 tapes) I have given up on this idea. One time only I got a usable recording (which was not loadable again). I don't know if it's the tapes or the datasettes and I lost patience trying to find out now.
- highinfidelity
- Vic 20 Nerd
Possibly both. But did you clean the datassette heads with cotton and alcohol?
- mrr19121970
- Vic 20 Nerd
This was the 1st thing I did.highinfidelity wrote:Possibly both. But did you clean the datassette heads with cotton and alcohol?
