VIC-1211 Super Expander WITHOUT 3K
Just found this while browsing the net:
at http://chipitos.be/main/index.php/mycol ... es/vic1211
Does anyone know how common these are? Would explain the VIC-1211A (always wondered about the 'A')
highinfidelity
Website: http://www.hirtel.it
Re: VIC-1211 Super Expander WITHOUT 3K
Post by highinfidelity »
Maybe yes, but I really don't know. The look of this cart, and of the box as well, is quite different by what I remember as being the standard design of Commodore products. Perhaps it was produced for some local market only (Japan?).
Interesting item, though.
Yep, typically the blue "V" on a white background was used on early boxes of VIC hardware, including the VIC itself. I believe most stuff was made Japan, but maybe also some early Western product was packaged like that. I really didn't know there was a 1211 Super Expander without the 3K RAM! Very limited use, I guess.
Post by Vic20-Ian »
How do you know it does not have 3K? Is this fact or assumption?
I saw no description of it running or tested?
Imperious
Post by Imperious »
More likely the "A" in the 1211A is a revision letter. Possibly they corrected a minor problem.
J.E.E.K.
Website: http://klasek.at/8bit
Post by J.E.E.K. »
orion70 wrote:Yep, typically the blue "V" on a white background was used on early boxes of VIC hardware, including the VIC itself. I believe most stuff was made Japan, but maybe also some early Western product was packaged like that. I really didn't know there was a 1211 Super Expander without the 3K RAM! Very limited use, I guess.
However, in spite the missing RAM the extended BASIC command set (hires graphic programming, music input helper, sound support) might helpful anyway. Not all language cartridges do have additional RAM. I couldn't proof it, but the following gives a certain indiction, that this is true.
See Description of a VIC-1211A
CanadaPhil
Post by CanadaPhil »
tokra wrote:Just found this while browsing the net:
The 3 versions of this cart are discussed in a bit of detail on pages 124 to 127 of the Vic Visual History Book.
:D
That one is the very first and definitely without the 3K RAM.
Next is the 1211M,
then the 1211A
