Hi;
I would like to trade a 16k cart. I have, for an 8k cart.
If anyone would like to do this, then let's mail each other the goods!
chris
8k cart. for a 16k cart.
If it's a Commodore, then you can cut in two places and then solder in a switch that has 8 switches on it, cut a hole in the front plate and then you will get a cart with two 8k blocks you can select freely.
/Anders
/Anders
Depending on your skill level you can do more or less anything. Go see ..
http://www.themotionstore.com/leeedavis ... index.html
While this is a bit extreme you can see the pads that select the blocks.
The C= 8K cart is just a 16K cart with half the chips missing, which is what the above was before I started on it.
Lee.
Lee.
The thing to look for inside is 8 points where you can solder and cut things to select blocks. The first 4 is for the first 8k block. The second 4 is for the second 8k block.
It should look like this:
Now if you want a cart that always is block 3 and 5, then you can just cut at 1 and 5 (or unsolder if they are soldered), then solder at 7 and 3 instead. But switches are of course nicer. Then go to an electronics component shop and bring the cart and ask for an 8-switches switch that fits on the other soldering points (the 16 dots above). Then just cut at 1 and 5, solder on the switching component and make a hole for it in the cart's metal cover. But with the switches like that, you won't be able to change the switches with the cart plugged in... For that you need to do something else... But this is probably the easiest way to make your cart switchable.
/Anders
/Anders
Okay, I just found out about being able to run cartridge ROM images by loading them off disk or tape into the proper memory segments.
I have two switchable ROM packs, but not documentation. Is there some sort of standard for the DIP switch settings so I can know which areas the RAM is being allocated to? Or is this detectable via some sort of POKE, so I can experiment to find out where the RAM is?
One of my cartridges is the famous "SPECIAL CARTRIDGE" by Audio Computers. I believe it has a set of 4 dip switches (can give a total of 24K RAM I think).
I'd use POKE and PEEK, perhaps with a couple of different values and positions to ensure it is not flakey.
BLK1: POKE a value into 8192-16383 and read it back with PEEK
BLK2: Ditto for 16384-24575
BLK3: Ditto for 24576-32767
BLK5: Ditto for 40960-49151
If you get a consistant read-out, there is functional RAM. If you get a different value than you poked and it changes for every PEEK, it is bus noise due to the memory area is unconnected.
way back then people used to add switches to flip the first bank between blk1 and blk3 and the second between blk2 and blk5. Flipping this second switch to blk5 would also make your ram expansion read only.
This was quite useful as it allowed you to load up any cartridge image in either blk1 and 2 or 2 and 3 then flip blk2 into 5, press the reset switch or type SYS64802 et voilà! you have a running game cartridge!
