On page 70 of Clas Ohlson's latest catalog, you will find one (or 3) suitable transformer(s). (Article number 32-8529) for 295 swedish crowns.Ray Carlsen wrote: > Another question... It is very hard to get hold of a substitute
> PSU for the old 2-prong european vic20 (220v AC -> 3A 9v AC.)
> At least two people are looking for one on the "Denial" forum.
> If everything is rectified inside anyway - then would it work
> just as well with a PSU that generates 3A 9v DC???
Anders,
After looking over the schematic, I believe it would work fine
with a DC supply. All DC sources derived from that AC power pack are
indeed rectified and used as either 9VDC (cassette motor) or 5VDC
(everything else). The only other place the 9VAC shows up is at the user
port. Unless something is plugged in there that needs the AC source, it
shouldn't matter that it's missing.
I don't like to give out information when I've not tried it
myself, but in this case, I don't have a problem with it. Note the
polarity of the DC supply source would not matter because of the bridge
rectifier in the computer. Whichever way you connect a DC input, the
rectifiers would reverse it if necessary.
Lastly, I've never tried to buy a 9 VDC 3 Amp adaptor, but it
seems to me that would be as rare as a 9VAC power pack. If I couldn't
find one, I'd probably buy a 9 volt transformer and install it in a
metal case to power my VIC. Even so, a three Amp would be unusual.
Ray
/Anders
