WIP: Manic Miner port
Kweepa
Occupation: Game maker
Re: WIP: Manic Miner port
Postby Kweepa » Wed Jan 31, 2018 9:36 am
Thank you very much!
I tracked it down to dying while holding down the jump button on the joystick.
Fixed in this version - which I think I'll call a release candidate :)
miner-20180131.zip
(10.9 KiB) Downloaded 23 times
miner-20180131src.zip
(33 KiB) Downloaded 17 times
Postby Mayhem » Wed Jan 31, 2018 12:06 pm
I see what you mean about the conveyor belts... that's definitely incorrect iirc, you can't just stop on them like that.
You're also missing The Vat... and the solar beam doesn't seem to do that much damage to your air supply.
merman
Occupation: Writer
Postby merman » Wed Jan 31, 2018 12:51 pm
Watched the video, very impressive!
Kweepa
Postby Kweepa » Wed Jan 31, 2018 2:04 pm
I must have accidentally cut the vat from the video while I was trimming out all my deaths. Oops!
Oh, that's how conveyors are supposed to work? Ugh. I think I prefer them this way - it feels much more logical.
Ah, and the light beams consume air? I didn't notice from the videos. Will fix this!
cobracon
Postby cobracon » Wed Jan 31, 2018 5:06 pm
Holy crap. This game will just wreck me. lol
hasseapa
Postby hasseapa » Wed Jan 31, 2018 5:24 pm
Superb. Another new VIC-game that makes you wonder how it could have changed things if it was released back in the days.
Postby Mayhem » Wed Jan 31, 2018 6:58 pm
Kweepa wrote:I must have accidentally cut the vat from the video while I was trimming out all my deaths. Oops!
Yes, the conveyors are constant progression, can't stop it, you have to time going onto them to progress correctly. That's part of the learning process for the level patterns. And yes, the solar beam reduces your air if it hits Willy, I generally finish that level with not much air at all because you can't really avoid it some of the time, that's part of the challenge. Also the dissolvable flooring is too slow imo, it should disappear quicker than it currently does. These aren't criticisms, just observations if you want to make the game as close to the original Spectrum/C64 versions as possible 8)
Kweepa
Postby Kweepa » Thu Feb 01, 2018 12:57 pm
Since you insisted... :)
Sped up the crumbling 50%.
Adjusted how the conveyors worked and tweaked a couple of levels to compensate.
Made the light beams suck air.
Postby srowe » Thu Feb 01, 2018 1:15 pm
This latest version starts in the Solar Power Generator...
Kweepa
Postby Kweepa » Thu Feb 01, 2018 1:49 pm
Ooooooops!
Postby beamrider » Thu Feb 01, 2018 4:48 pm
miner-20180201.zip still starts in Solar Power Generator
Kweepa
Postby Kweepa » Thu Feb 01, 2018 4:59 pm
WTF? Let me try that again.
Postby Mayhem » Thu Feb 01, 2018 6:36 pm
Now that's pretty much spot on :)
Makes a couple of those jumps a lot more precarious and needs the correct timing (Sixteenth Cavern, and Solar Power Generator especially). In fact it only took me two attempts to complete The Warehouse!
Only bug I spotted was that the high score didn't appear to be saved, completed a game and started a new one, and the high score was still zero.
Kweepa
Postby Kweepa » Thu Feb 01, 2018 7:14 pm
Really, only two attempts?? It took me about 30 attempts when I was recording the walkthrough!
Fixed the high score.
miner-20180201b.zip
(10.95 KiB) Downloaded 85 times
miner-20180201bsrc.zip
(33.12 KiB) Downloaded 46 times
Postby Mayhem » Fri Feb 02, 2018 6:23 am
Will check that out over the weekend. Btw why use the Bug Byte version for inspiration, and not Software Projects? Because it was the original?
Return to “Games”
Who is online
