Hello,
Just did a TAP2WAV transfer to a real cassette this past weekend of Hell Gate by Jeff Minter and the screen is far off center and I can't really tell if there is some key combo to center it manually or not, or is this just how it is for NTSC VICs?
Thanks,
Rich
Llamasoft Hell Gate, off centered on all NTSC systems?
- CannibalCat
- Mayhem
- High Bidder
Re: Llamasoft Hell Gate, off centered on all NTSC systems?
Considering it's a PAL only game I believe, with no screen centring controls, then you're probably SOOL.
- CannibalCat
That's what I thought, thanks for the info!Mayhem wrote:Considering it's a PAL only game I believe, with no screen centring controls, then you're probably SOOL.
I downloaded Hell Gate from here: ftp://ftp.zimmers.net/pub/cbm/vic20/gam ... llgate.prg. Then, after loading the game, but before running it, do these two POKEs:
... to create a version that's (hopefully) centered for NTSC on your monitor. You might try values 1..3 for the horizontal alignment in the first POKE, and 6..10 for the vertical alignment in the second POKE. And save away the modified version, so you don't have to reenter the POKEs.
POKE 6928,2
POKE 6945,8
Yeah. Or not?Mayhem wrote:Considering it's a PAL only game I believe, with no screen centring controls, then you're probably SOOL.
- CannibalCat
[quote="Mike"]I downloaded Hell Gate from here: ftp://ftp.zimmers.net/pub/cbm/vic20/gam ... llgate.prg. Then, after loading the game, but before running it, do these two POKEs:
Ok cool, I'll give this a shot later...thanks man.
POKE 6928,2
POKE 6945,8
- Mayhem
- High Bidder
Based on running the real TAP/tape, as CC said he used TAP2WAV, then that's what my comment was based on. The game has a short loader, which then takes the rest of the code off the tape and auto starts iirc. So you wouldn't be able to type in POKEs before running. As you state, you would be able to perform some jiggery-POKEry if you used the one-filed PRG instead.Mike wrote:Yeah. Or not?
The difference being, that while your first post in this thread was of no help at all, I at least gave a working solution for the *.prg file at zimmers.Mayhem wrote:Based on running the real TAP/tape, as CC said he used TAP2WAV, then that's what my comment was based on.Mike wrote:Yeah. Or not?
Furthermore, you couldn't really infer from the use of TAP2WAV, that CannibalCat actually used a *.tap file made from the original game. It could quite as well been produced by a emulator save of above *.prg into a *.tap
Whatever. I am quite confident, that I could provide a pre-boot loader, which then would take control over the original (fast?) loader and autostart of the original tape, apply the POKEs, and then start the game.The game has a short loader, which then takes the rest of the code off the tape and auto starts iirc. So you wouldn't be able to type in POKEs before running. As you state, you would be able to perform some jiggery-POKEry if you used the one-filed PRG instead.
But in just that case here, I can't anymore be bothered.
Good night.
The Original Poster here was polite at all times, so seems a bit unfair that this ended as abruptly as it did.
That's just my 2c, but given how small a community this is, we don't want it getting smaller.
- CannibalCat
Imperious wrote:The Original Poster here was polite at all times, so seems a bit unfair that this ended as abruptly as it did.
No worries man! All good.
