Hmm.. it has a button lock. You have to release button between flaps. Is this Win PC keyboard feature? (repeat key or something?) My Mac does not have this problem.beamrider wrote:Getting better.....
Main issue now I think is that if you press and hold down the button it flaps multiple times. This sometimes pushes you into the columns and kills you, if you hold down a little longer than intended.
Can you put a lockout in so you have to release and repress the button for each flap?
Once again thanks. Great work....
ViccyBird
Re: ViccyBird
Re: ViccyBird
On vice with Xbox 360 controller. OK will try on real Vic and let you know
Re: ViccyBird
Ok you're right, it doesn't do this if I switch to keyboard setting in vice.
I'll edit my original post.
Re: ViccyBird
Tested again on real hardware and it seems to play much better now!
Re: ViccyBird
Cool,
I made few gfx bug fixes yesterday. Download PRG again if you want to play latest version.
