Too bad... I guess you have to use white background on the loading screen then - unless you like the garbage.Mike wrote:When the picture is loaded while text mode is still on, the bottom half of the text screen is written with the first bytes of the picture bitmap. This data was not visible on white background before, because the VIC-20 kernal initialises Colour RAM always with white colour (and not the cursor colour!) on a screen clear.
BUG:
I noticed there's no "loading-warning" after refusing to rescue the kidnapped son, it just says SEARCHING FOR INN and loads the picture.
bug:
"THE DWARVES ," -> "THE DWARVES,"
The dice rolling is wrong again when rolling against dexterity, it says I need to get MORE (than 12), I get more (14) but I fail.
And again:
AMBUSH get MORE than your intellect (16), I rolled 7 and made it!
bug:
"YOU´RE BACK TO THE INN" -> "you're back at the inn" ?
