rca adpter cable - vic 20
redgrass
Postby redgrass » Tue Sep 05, 2017 5:33 pm
Can anyone tell me if the rca adapter cable for the vic 20 works properly??? eg.
http://www.ebay.com/itm/Cable-AV-Commod ... SwcwhVKV3M
Re: rca adpter cable - vic 20
Postby srowe » Wed Sep 06, 2017 1:00 am
Looks like the same cable as I use with my VIC.
ridgerunner
Postby ridgerunner » Wed Sep 06, 2017 3:37 am
I'm using a similar cable on both my VIC & C16, I got mine from ebay seller Retrocomputershack, it's works lovely and is very well made. I also bought a SCART lead for my speccy +2 from them and that is up to the same high standards.
Floopy
Postby Floopy » Thu Sep 07, 2017 9:07 am
If you have a soldering iron and a nice steady hand you can build one yourself.
Anyway, if it works for the C64 it will work for the VIC-20. The pinouts on the ports are almost identical.
You may need to adjust your picture though.
-Floopy
Floopy
Postby Floopy » Thu Sep 07, 2017 9:19 am
I wanted to post the pinout out but it wont work. The difference between the vic-20 and c64 video output is pin #1 on the vic it's 5V+ and on the 64 it is luminance .
-Floopy
Meteo VIC
Postby orion70 » Fri Sep 08, 2017 5:46 am
Commodore video pinout, computer side:
Universal (C64 - VIC - C16 - Plus4)
C64 and Plus4 only w/separate luma and chroma (better quality)
Return to “General Topics”
Who is online
Users browsing this forum: Google [Bot] and 1 guest
