Toaster.
Toaster.
Postby R'zo » Sun Jun 18, 2017 11:02 am
I would like to suggest that the 2-pin bread bins should be referred to as toasters. I think it sounds fitting. ;)
Boray
Musical Smurf
Re: Toaster.
Postby Boray » Sun Jun 18, 2017 11:29 am
I think they smell more like a waffle maker.
Re: Toaster.
Postby R'zo » Sun Jun 18, 2017 11:56 am
Boray wrote:I think they smell more like a waffle maker.
LOL :D
Re: Toaster.
Postby eslapion » Sun Jun 18, 2017 12:49 pm
If they are toasters when why do they actually have fewer venting slots ?
Re: Toaster.
Postby R'zo » Sun Jun 18, 2017 1:20 pm
eslapion wrote:If they are toasters when why do they actually have fewer venting slots ?
Good question, but i'd bet if you were to put a piece of bread in the expansion port you'd have toast after an hour. (Disclaimer: nobody try this) :D
Boray
Musical Smurf
Re: Toaster.
Postby Boray » Sun Jun 18, 2017 1:45 pm
Do they? Anyway, I don't think I've ever seen a toaster with venting slots.
Gorf
Re: Toaster.
Postby Gorf » Tue Jun 20, 2017 10:16 am
R'zo wrote:I would like to suggest that the 2-pin bread bins should be referred to as toasters. I think it sounds fitting. ;)
I do think they smell slightly like bread (or another baked good) when they are on for a while. :D
Be kind, rewind
Re: Toaster.
Postby eslapion » Tue Jun 20, 2017 3:14 pm
@R'zo
The term 'toaster' in the Commodore/Amiga world refers usually to the Video Toaster which was destined to be used on later generations of Amiga computers.
I might suggest we refer to the 2-Prong PSU VIC-20 as 'The Furnace'.
Muzz73
Occupation: Consultant
Re: Toaster.
Postby Muzz73 » Tue Jun 20, 2017 10:29 pm
Yes... that. :lol:
BCNU,
Louis
Gorf
Re: Toaster.
Postby Gorf » Thu Jun 22, 2017 5:01 am
"Hot Plate" might be an option. There is quite literally a hot plate of metal right above the cartridge port, so that might work. :mrgreen:
Be kind, rewind
Re: Toaster.
Postby R'zo » Thu Jun 22, 2017 6:50 am
Gorf wrote:"Hot Plate" might be an option. There is quite literally a hot plate of metal right above the cartridge port, so that might work. :mrgreen:
I like it.
Re: Toaster.
Postby eslapion » Thu Jun 22, 2017 7:15 am
Yup, seems a good name for it.
Gorf
Re: Toaster.
Postby Gorf » Thu Jun 22, 2017 7:31 am
I like it.
Thanks :D
Thank you too :D
Be kind, rewind
Floopy
Re: Toaster.
Postby Floopy » Thu Jun 22, 2017 9:26 am
:lol:
-Floopy
Boray
Musical Smurf
Re: Toaster.
Postby Boray » Thu Jun 22, 2017 10:12 am
The Breadmaker
Return to “General Topics”
Who is online
