Term
- plbyrd
- Vic 20 Hobbyist
- Website: http://thesharp.ninja
Term
Anyone have VIC term that supports color PETSCII at 2400 on the Userport?
- Website: http://bbs.centronian.ca
Re: Term
I've actually been working on a term in basic called ViuTerm. It supports PETSCII and works at 1200 baud. It also has a 1kb buffer, but its still a work in progress. I'll post it sometime soon as a software release for the year.... but until then... I've been beta testing it on my BBS (centronian.servebeer.com 6400) where its been available for download for awhile. You can download it from the BBS or from the website.
Here is the terminal:
http://centronian.servebeer.com/files/viuterm0.20.prg
And here is the documentation:
http://centronian.servebeer.com/files/v ... .2-dox.txt
Let me know how it goes!
- plbyrd
- Vic 20 Hobbyist
Re: Term
Thanks for the links! I'll be downloading it soon.
Re: Term
Any modem that did support this speed at the user port? Most commodore modems seems to have been up to 1200baud unless you went for a RS-232 interface with a modem through that.plbyrd wrote:Anyone have VIC term that supports color PETSCII at 2400 on the Userport?
- plbyrd
- Vic 20 Hobbyist
Re: Term
@alterus
Your webserver doesn't have a mime type for PRG files. You need to add one with "application/octet-stream" as the value.
Re: Term
Ok I'll look into that. Where you able to download ViuTerm? The download works fine for me...plbyrd wrote:@alterus
- plbyrd
- Vic 20 Hobbyist
Re: Term
No, it just dumps it as UTF8 text in my browser.
Re: Term
Oh crazy... I'm using Ubuntu 14.04 and it works perfectly. Are you using Windows? I didn't realize this was an issue... I'll fix it. Try right click, save link as...
