I don't have my source code here now, but I remember not implementing printer output to save some memory. Instead of returning internal error it should just ignore the command though. That was the case when I tested the commands, but that was early on during the development so some later interpreter change may well have broken it.orion70 wrote:I read that Infocom adventures can output the story script to a printer with the simple command ">script".
Tried it immediately with TNT's incarnation in VICE with a virtual printer as device #4, but it gave an internal error:
Setup improved and a new printer :)
Re: Setup improved and a new printer :)
- highinfidelity
- Vic 20 Nerd
Bad news for orion70 and his new little printer in any case!
Thanks TNT, I won't even try this at home
Same problem with the other Infocom adaptation (i.e., the buggy Pet Food one). It hangs in VICE; no error message, but it freezes after RETURN is pressed (light on due to direct access):
Maybe I'll try with this on the real VIC instead.
At some point I cut down VAR opcodes ($e0-$ff, 224-255)* dispatcher table down to 12 entries in the V3 interpreter. That is clearly a bug as there are three more V3 opcodes in that range. That may get fixed some day if I find a moment or two to add EF3/UltiMem support.TNT wrote:I don't have my source code here now, but I remember not implementing printer output to save some memory. Instead of returning internal error it should just ignore the command though.
* http://inform-fiction.org/zmachine/stan ... 4.html#VAR
That would be great, thanks in advance TNT
In the meantime, I found this cover of Electronics and Computing Monthly, a UK magazine, apparently reviewing the AM VIC expander in the Apr. 1982 issue. No results in searching scanned pages of the magazine - anyone has the paper, or can provide me with a link? TIA.
Bumpity bump. TNT, any news about implementing printer output in your port of Infocom text adventures?TNT wrote:At some point I cut down VAR opcodes ($e0-$ff, 224-255)* dispatcher table down to 12 entries in the V3 interpreter. That is clearly a bug as there are three more V3 opcodes in that range. That may get fixed some day if I find a moment or two to add EF3/UltiMem support.TNT wrote:I don't have my source code here now, but I remember not implementing printer output to save some memory. Instead of returning internal error it should just ignore the command though.
..and the long shot, anyone out there has this issue of Electronics and Computing Monthly?
TIA
P.S. Found a two-pages review of the AM Expander in vol.1, issue 4 of VIC Computing (download the review HERE, 1.88 Mb).
