Hi all,
I'm using VICE with a laptop.
Can anyone recommend a joystick (USB I would guess?) for use with VICE that is good and reliable?
Good Joystick for use with VICE?
- JohnnyRockets
- Occupation: IT Manager
Thanks!
JR
JR
Re: Good Joystick for use with VICE?
You can get 9-pin to USB adaptors that will enable you to use joysticks from the good old days:
http://www.retronicdesign.com/en/
My joystick of preference is the Mindscape Powerplayer but most people seem to favour the Zipstick or Competition Pro. I believe there are contemporary USB versions of the latter joysticks available but they tend to not be as good as the originals.
