"Ohne Dich": Play digital audio from tape in real-time
Re: "Ohne Dich": Play digital audio from tape in real-time
You can use the album you won in the "Vic-20 game awards of 2014" if you like. Was it "Time for Boray"?
- pixel
- Website: http://hugbox.org/
Yes, that was the one. Thanks!Boray wrote:You can use the album you won in the "Vic-20 game awards of 2014" if you like. Was it "Time for Boray"?
Spotted a fellow Canadian right away as soon as I heard your accent!freshlamb wrote:I used AudioTap to convert, Wavelab for any adjusting, and just recorded on my tape deck. So perhaps there is a degrading of the sound. Here is a video link. https://www.youtube.com/watch?v=PahhRvIVdVM
- pixel
The player is now IRQ–based. One might expect less jitter/noise but that didn't happen. The good thing is, of course, that audio samples could now be played in games.
- pixel
The player got pushed to the very limits on real hardware. The archive at http://hugbox.org/pixel/external/denial/ohne_dich6k.zip contains all TAPs and WAVs for both PAL and NTSC to play the tunes at 6kHz sampling rate. 6.5kHz would have come with audible distortions. (Boray's track on "Pulse" has been recorded with 5kHz to play safe.)
The WAVs have been generated with the only TAP2WAV converter I trust: mine.
- pixel
One more thing: this time the recordings start with a test tone which is fading out from maximum volume. If your recorder and your datassette are well–adjusted the bars on the screen should look exactly like they do in VICE.
- pixel
Oh my. One more thing missing: this time your memory configuration doesn't matter. Your VIC will relocate the code.
Wait - something I cannot understand from the original description of this program:This piece is supposed to play a tune from tape with about 4kHz sampling rate at four bits on unexpanded VICs. Unfortunately, I can't test it on real hardware.
Is it reading analogue audio off the cassette and sampling on-the-fly, or a pre-prepared digital sample file/stream?
i.e. can I put in any analogue audio cassette and have it play, or must it be digitally sampled audio saved as a file to a cassette?
- pixel
Oh, you're right. Maybe I took it for too granted. It really doesn't play any audio tape. The samples need to be pulse width modulated to make it through. The player measures the lengths of the pulses and performs some simple statistics to adjust itself.ral-clan wrote:i.e. can I put in any analogue audio cassette and have it play, or must it be digitally sampled audio saved as a file to a cassette?
Okay, thanks, because there is already software out there that will play audio off an analogue cassette through the VIC-20's audio out, so I wasn't sure what you had come up with.pixel wrote:Oh, you're right. Maybe I took it for too granted. It really doesn't play any audio tape. The samples need to be pulse width modulated to make it through. The player measures the lengths of the pulses and performs some simple statistics to adjust itself.ral-clan wrote:i.e. can I put in any analogue audio cassette and have it play, or must it be digitally sampled audio saved as a file to a cassette?
- pixel
Sounds scary. Where can I get that one?ral-clan wrote:Okay, thanks, because there is already software out there that will play audio off an analogue cassette through the VIC-20's audio out, so I wasn't sure what you had come up with.
Here's some information:
The program TAPE TON at the web page here does it:
http://www.geocities.ws/cbm/bin/tapeton.prg
Here's some more info:
http://www.lemon64.com/forum/viewtopic. ... e960bf61fe
- pixel
Oh dear. I guess I can imagine the result already. No C64 set up at the moment. Anyway: you got me hooked on the idea to try something like that out myself. Not as simple as the example on Lemon. Hmm... hmm... tricky.
TAPE TON works with the VIC-20. It's bad, yes, but not that bad. I recall it was good enough, in my testing, for me to play a 440Hz tone recorded on analogue cassette to help me calibrate the datasette motor speed.pixel wrote:Oh dear. I guess I can imagine the result already. No C64 set up at the moment. Anyway: you got me hooked on the idea to try something like that out myself. Not as simple as the example on Lemon. Hmm... hmm... tricky.
- pixel
I played around with audio recordings last night and didn't get anything usable out of it.ral-clan wrote: TAPE TON works with the VIC-20. It's bad, yes, but not that bad. I recall it was good enough, in my testing, for me to play a 440Hz tone recorded on analogue cassette to help me calibrate the datasette motor speed.
